How to reset Ulaa to default settings?
You can reset Ulaa to default settings if you are facing any issues with the browser or due to unwanted changes done by an extension. Resetting Ulaa will remove any changes you have done to the browser and enhances the browsing experience.
Resetting Ulaa
  1. At the top right, click  Menu.
  2. Select Preferences.
  3. Choose Reset settings.
  4. Select Restore Settings to their original defaults > Reset settings.
Note:
  1. Bookmarks and passwords will not get deleted.
  2. Resetting to default settings won't provide a full reset.
Changes due to Reset settings
  • Default search engine will be set to DuckDuckGo.
  • Homepage and tabs that you have set previously will be removed.
  • New Tab page will appear empty.
  • Pinned tabs will be deleted.
  • Content settings, like letting a site show your pop-ups or use your microphone will be cleared.
  • Browsing history, cookies and site data will be cleared. eg. Groceries in your online shopping cart will be cleared.
  • Extension and themes will be disabled.
