How to Switch from System-Level installation to User-Level Installation in Ulaa
Switch from system-level to user-level installation in Ulaa
  1. Quit Ulaa and all associated processes in the task manager then uninstall Ulaa from the control panel. Ensure "Also delete your browsing " is unchecked.
  2. Select Uninstall.
  3. Download Ulaa
  4. Right-click on the .exe file and choose "Run as administrator"
  5. Now choose "User-level" Installation (This impacts only the selected user profile).
  6. You can find Ulaa in this directory :  C:\Users\<user_name>\AppData\Local\Zoho\Ulaa
Uninstalling Ulaa will not cause any data loss. However, to eliminate any risk, please activate sync for each mode before proceeding with the uninstallation.
For any additional queries or assistance reach us at https://ulaabrowser.zohodesk.com/portal/en/newticket
Want to share your feedback? Write to us at https://ulaa.com/feedback
    • How to Completely Uninstall Ulaa on Windows ?
      If you're facing issues while reinstalling Ulaa or need to remove it completely from your system, follow the steps below to ensure a clean uninstallation. Method 1: Uninstall via Control Panel Open Control Panel, press `Windows + R` to open the Run ...
    • Ulaa browser system requirements
      Ulaa Browser is accessible on a multitude of platforms, including Mac, Linux, Windows, iOS, and Android, ensuring compatibility with a wide range of devices and operating systems. Before you start the installation process for Ulaa Browser, make sure ...
    • How to install Ulaa using command prompt in Windows?
      Download Ulaa. Open the command prompt in your Windows PC. Navigate to the downloaded file path and type the file name. Choose the command according to your need - System/User level. To install Ulaa at the system level use --system_level System Level ...
    • How to switch between open tabs easily?
      Imagine you have ten open tabs on your browser. Constantly clicking on your mouse or relying on your trackpad to switch between them can be difficult. Fortunately, by using the keyboard shortcuts listed below, you can comfortably access your open ...
    • How to switch on autocomplete searches?
      Autocomplete searches and URLs are a list of predictions, offered by your default search engine to enhance your search experience. It helps you save time by giving suggestions related to the search you type. You can switch off the feature. To do so: ...
