What is hardware acceleration? How to enable it?
Hardware acceleration is a process where Ulaa unloads certain tasks to your system's hardware in an attempt to accelerate a task.
How to enable hardware acceleration?
- At the top right, click
Menu.
- Click Preferences > Browser Settings.
- Toggle "ON"- Use hardware acceleration when available.
Related Articles
What is caret browsing? How to enable it?
Caret browsing an alternative way of navigation that provides you with a movable cursor to navigate webpages. When you enable caret browsing, you can navigate webpages using a text cursor. How to enable caret browsing? At the top right, click Menu. ...
How to enable "Show warning before quitting with command+Q"?
This prevents accidental quitting and helps users avoid losing unsaved work by prompting a confirmation dialog before quitting an application using the Command+Q shortcut. To enable "Show warning before quitting with command+Q, On the top right, ...
How to enable Smart dark mode for webpages?
Dark Mode provides a comfortable browsing experience at night or in low-light conditions. To enable dark mode At the top right of the address bar, click the sun icon. This will automatically turn all the webpages to dark mode. For any additional ...
How to enable Cycle through your recently used tabs with Ctrl+Tab option?
Switch back to recently used Tabs If you wish to switch back to your recently used tabs instead of moving back and forth, you can enable the Cycle through your recently used tabs with Ctrl+Tab option. To do so: At the top right, click Menu. Click ...
WebGL-Supported Website Not Working in Ulaa: How to Fix It?
WebGL-supported sites, such as https://vrseat.vercel.app/, may not work when hardware acceleration is enabled in Ulaa. To resolve this: 1. Navigate to the Hamburger icon in the top-right corner of Ulaa > Preferences > Browser Settings, and disable ...
